How do I reinstall or upgrade Driver Reviver?
Discussions on Driver Reviver
Postby Reggie » Tue Mar 08, 2011 11:45 pm
Are you looking to reinstall or upgrade Driver Reviver on your computer?
Well, here are a few easy steps for you to follow:
Step 1: Uninstall the current version of Driver Reviver from your computer.
( Start > Control Panel > Add or Remove Programs > Driver Reviver > Remove/Uninstall )
Step 2: Download and install the latest version of Driver Reviver from here.
Step 3: Please make sure you stop any internet based programs such as Download Managers, P2P software, so as to ensure sufficient internet bandwidth for Driver Reviver.
Step 4: Open the Driver Reviver program and register it using your license code.
( Click here for the complete product guide )
Step 5: Run a scan and repair all the errors detected.
Congratulations! You have successfully updated your program to the latest version available. :)
A reinstallation is also helpful when you encounter unexpected problems with the program. 8-)
Questions or concerns? Let us know.
Return to Driver Reviver
