How do I Maintain my PC using PC Reviver?
Discussions on PC Reviver
Postby RS_Admin » Wed Feb 12, 2014 2:07 am
Complete PC Maintenance using PC Reviver
PC Reviver includes a great set of tools to help you understand your computer, troubleshoot common problems, boost startup time and maintain other aspects of your computer.
The different tools are explained below:
1. Crash Helper
PC Reviver can help you identify, troubleshoot and fix blue screen or STOP errors quickly and painlessly, saving you a whole lot of time and grief!
If you have recently encountered a blue screen error on your PC, launch PC Reviver, click on the Maintain tile from the Home screen, then click the Crash Helper tile. In the screen that appears, enter the error code (For example: 0x000000F4) you noticed on the blue screen message and click the Ask Now button to find out more about the error and learn how to fix it.
2. Driver Backup
PC Reviver has been developed to include the essential tools to help you keep your PC running at its best. This includes a Driver Backup tool in the Maintain section of the product. To backup your drivers, click on the Maintain tile from the Home screen, then click the Driver Backup tile.
You have the option to backup all the drivers on your system or specific individual drivers. Choose which option you want to perform, hit next and follow the on-screen instructions.
3. Duplicate Finder
PC Reviver can help find duplicate files in a folder or directory quickly. To find and delete duplicate files, click on the Maintain tile from the Home screen, then click the Duplicate Finder tile.
You have the option to scan your whole computer or specific folders. If you want to scan your whole computer, simply hit Scan to commence your duplicate file search.
If you want to search within a specific directory or folder, click on Select Folder to browse and choose the folder, hit Select Folder and then click the Scan button.
Once the scan is complete, you will see a list of duplicate files that were found. The original file will be unchecked, while the duplicates found will be checked. Review the files and keep the ones you do not need checked, click the Delete button and you are done!
4. File Extensions
PC Reviver makes it easy to fix file extension problems and manage all the file extensions on your computer. To access the File Extension Manager, click on the Maintain tile from the Home screen, then click the File Extensions tile.
5. Process Library
PC Reviver can help you better understand the different processes that run on your computer. To access the Process Library and start learning about different processes, click on the Maintain tile from the Home screen, then click the Process Library tile.
Once the Process Library window has loaded, you can either search for a particular process or click on the first letter of the process file name if you are not sure. After you have selected a process, you will be able to read up everything there is to know about the process you are interested in and become more familiar with the processes that run on your PC.
6. Registry Defrag
The Windows Registry is an important part of your Windows Operating System. The Registry Defrag feature helps you defrag the Windows Registry completely and optimize it for smooth performance. Using the Registry Defrag feature regularly improves your system performance and keeps it running smoothly.
To use this feature, click on the Maintain tile from the Home screen, then click the Registry Defrag tile. In the Registry Defrag window, click on the Analyze button to start scanning your Registry.
Once the scan is complete, you can review the scan results and click on Optimize to start defragging your Registry.
Note: To complete the defrag and optimization process, the program may schedule itself to run during the next system boot. After the process is complete, your computer will boot normally and start loading Windows
7. Startup Manager
If you are looking to improve and maintain the startup speed or boot time of your computer, PC Reviver gives you full control to turn off or turn on any program or service using the Startup Manager feature. To get started, click on the Maintain tile from the Home screen, then click the Startup Manager tile.
Once you are in the Startup Manager window, you can look through the list of startup programs and services currently running on your computer and turn off unnecessary programs and services by clicking on the green switch next to each program or service. If you are not sure about a program or service, simply consult our support team and they will be happy to guide you.
8. Uninstall Manager
PC Reviver can help you uninstall and remove unnecessary program from your PC in a few simple clicks. To get started, click on the Maintain tile from the Home screen, then click the Uninstall Manager tile.
Once you are in the Uninstall Manager window, browse through the list of programs installed on your computer, locate the program(s) you wish to uninstall and click the red Trash Bin icon to start the uninstallation process. Follow the onscreen instructions to successfully uninstall the required program(s) from your PC. Note: You can also repair an installation by clicking on the cog and wrench icon.
Need help with one of these tools?
Submit a support request
Return to PC Reviver
