How to move or backup your Settings and Customizations
Discussions on Start Menu Reviver
Postby Reggie » Wed Mar 05, 2014 11:53 pm
If you are looking to move all your settings from Start Menu Reviver to a different computer or backup your settings and customizations before a reinstallation, here is what you need to do:
1. Go to: C:\ProgramData\ReviverSoft\
2. Copy the entire Start Menu Reviver folder
3. Reinstall Start Menu Reviver at the final destination
4. Exit Start Menu Reviver
5. Go to: C:\ProgramData\ReviverSoft\ on the final destination
6. Paste and replace the entire Start Menu Reviver folder
You will now be able to launch Start Menu Reviver with all your settings and customizations in place.
Return to Start Menu Reviver
