Are you having trouble with your current installation of Windows? Are you experiencing problems with system files or a specific functionality of Windows?
Most importantly, are you on the verge of formatting your hard disk and re-installing Windows, risking the loss of data?
Well, there's one last option you can consider.
A Repair installation of Windows.
What do I need?
- Your Windows Operating System (OS) Install disc
- A working CD/DVD Drive
How do I proceed?
I've picked out a few guides for each Windows operating system. Simply click on the link that corresponds to your Operating System.
For Windows XP:
Repair guide
For Windows Vista:
Repair Guide
For Windows 7:
Repair Guide
Your Windows installation should now spring back to life, after the repairs are carried out!
I would also recommend the periodic usage of Registry Reviver, to keep your computer free from registry errors and maintain its stability.
Happy computing!
